hi,
if anyone is out there about to do a lift install can you measure something for me???
I have a pro4x titan and looking to do a lift, i bought it used an prior owner put 5100's at stock height snap ring.
can someone please measure the oem length of their shocks if you have them off the vehicle?? measure from top of perch to center of the mount hole.
like in this picture it measures 19 inches from top of 3 bolt plate to center of lower hole:
-J
Wow... you didn't get any responses? OK, OE Rancho front shocks from 2014 Pro4X measure 15-1/4" from top mount to center of lower bolt.
ha.! thank you so much! im working on this project again now... im finding same as you about 15.25 inch (some 15.5") stock and then the spacer lifts add about 1.6 inch to that - making 16.85 total. ~17 inch or so...
I'm questioning only because on my Titan swap Xterra i used 00-06 1st gen Tundra Bilsteins with lower perch adjust-ability and with tundra 595# springs they were perfection on my Xterra with winch and armor bumper and given the titan spring force numbers im considering do it to the titan and doing the max 3 inch lift with no spacers...all spring and shock...
Thanks,
-J
