I was hoping soemone could measure their non E-Locker rear axle shaft length for me?
I just installed a true-trac a few weeks ago on my '05 Titan with BT and factory E-locker. I did verify that the driver's side axle is too short as a few people had commented in the forum. So, being pro-active to not just let it strip out, I ordered a complete axle assembly with seal and bearing already installed from Courtesy Nissan. I ordered the non E-locker version, which is part number 38163-8S10A. When I recieved it, I took out my old one and compared it to the new one. They were exactly the same length! I called the dealer and they told me that the part number is correct. I have seen some "guesses" in the forums that say the standard axle is about 44". The dealer did tell me that the driver's side E-locker axle states it is 33.36" from outside face of flange to end of spline. I was hoping someone may have an axle sitting around they could measure for me. I need the standard (non E-locker) axle length from the outside of the flange to the end of the spline? Any help would be greatly appreciated. The Nissan dealer tells me he doesn't believe me! Thanks!
