1 - 17 of 17 Posts
Cleaning out the garage. Give me a fair offer and pay for shipping and they are yours. Some are heavy so you are welcome to come pick them up.
-PRG extended travel SAWs. SOLD
-Bilstein 5100s-SOLD
-Icon shocks, many miles but they still worked when I took them off. They are suited for 1-2 inch lift.
-PRG 1 inch aluminum blocks.
-U bolt sets, 10 inches long and 8 inches.
-MotoFab front 2 inch lift spacers (leveling kit)
-PRG UCA rod end rebuilds
-Rough Country traction bar stock rod ends
-Stock brake line brackets
-Smaller skid plate only
-Spindles 145k miles on them
-Cross member
-Front license plate holder
-AC drain tube
-PRG sway bar links. After reinspection, found to be bent.
-PRG can bolts (new)
Sent from my SM-G973U using Tapatalk
Discussion Starter #4
How much for the rear spacers, u-bolts and Bilstein's? Or would they work with the spacers?
Not sure which you are referring to. The Bilsteins are for stock height, not sure if they would cause any issue since the spacers are only 1 inch. The U bolts are 10 inches long. I believe they were the ones that came with the kit but not sure, it's been a while. If you measure your stock U bolts and they are shorter than 10 inches, these will work for you. PM me your info and what you want so I can get an idea of the shipping. I'm not trying to get rich off this, just trying to cover the expense to ship and a few extra bucks for my troubles.
Discussion Starter #8
Discussion Starter #9
Bump
Discussion Starter #10
Plenty of parts till available.
Discussion Starter #11
Bump
Discussion Starter #12
Update- Found some more U bolts and PRG cam bolts. Pic above.
Discussion Starter #13
Bump
Discussion Starter #15
Coilovers are sold
Discussion Starter #16
Bump
Discussion Starter #17
Bump
1 - 17 of 17 Posts
