Hey guys,
I'm trying to buy a set of flares and a member has a set with the toolbox as an option. My truck is an XE with no toolbox.
I had a brilliant idea that I could probably seam the opening shut, use some bondo or some sort of 'filler' and then sand/bedline over it.
Anyone ever done this or attempted this? Thoughts on if a guy could make this work or if its worth it? My other option is to go ATS flares and bedline them instead.
Thanks.
Trev
hahaha good luck! :) the distance between the two pieces is not to great. I'll check to see if i have a pic of what it looks like.
Here ya go!
Discussion Starter #4
Heh thanks man! I actually found that pic looking through your posts to see if I could see what they looked like.
Bedliner does some awesome things! We'll see what happens with the other guy interested but could probably make them work. Forgot to ask you, did you bedline them before or are they factory unpainted?
No problem. Ya I bedlined them.
