Pepst said:
Question for you guys..I've searched and am not 100% on the answer. I want to put these: Moto Metal 20x10, 6 on 5.5 / Bolt Pattern; Back Spacing = 5.02 in.; Offset = -12 mm.; Hub Bore = 106.25 along with Toyo M/T 35-12.5/20. My truck will be lifted w/4" CST spindles and SAW coilovers.
Can anyone tell me for sure if they will fit as well as any problems i may encounter with rubbing.
Thanks..
The main concern is if this setup will rub on the spindles, because only a wheel spacer can help you then.
This backspacing gives 1/2" more clearance than OEM rim's with their 5.5" backspacing, but the tire sidewalls are much wider than OEM, and will stick in and out at least an inch more. This is probably why CST states 4.75" backspacing for their spindles. Some use the OEM rims with 5.5" b.s., with no problem, but with skinnier tires, (plus an 7.5" or 8" rim will pull in even a wide tire by 2/10 of an inch for every 1/2" narrower than the spec sheet measuring rim.
So, a 4.5" backspacing will be better for spindle clearance ... but worse for the pinch weld fender rub ... when you are turning the steering wheel. Those 10" wide rims will also affect this type of rub. You are much better off with a 8.5" to 9" width rim, even if you have to go with 18s or 17s.
Also the hub bore size is too big for the Titan. Thats like a 4" and I think ours is very close to 3". If it's a lug centric design I guess it doesn't matter, but I think a hub-centric might be stronger for a 2.5 ton truck if you off road.
yscty said:
Your best bet will be to stay away from any Negative Offset!!!
If he were to go a positive offset, or even just with 0 offset, he would be rubbing the CST spindles with the 13" wide Toyo MTs. Probably even on the stock steering knuckles.
Backspacing is what matters. Offset changes depending on the wheel width ... for a given backspacing.
