I got the same kit, and had to cut that end off and reattach on the inside of the cab.Today was the failed wiring attempt #1. Got hung up when i saw that the square inch plug (pic 1) is going to have to go through the tiny firewall hole :huh:. My new plan is to strip the plug and pull the wires through with a coat hanger, and reassemble the plug. Got the button installed and it looks great (pic 2).
I would really like someone to confirm my planned wiring. The third pic is the fog diagram with my relay diagram. My parking lights are gonna be the switch to activate power to the wiring harness, which will then power my button and fogs. Any help would be appreciated. :teeth:
So you used 2 relays then? I hate electrical work ughh....Got them wired up! The wiring diagram i used for the relay is attached after the pics Holler at me if you have questions about the install.
Nah man, I just wired up one relay. The power goes to my fog wiring harness when parking lights are enabled.So you used 2 relays then? I hate electrical work ughh....
I also have an ebay kit for my XE as well but they sent different pigtail for the bulbs so i found some on a JY truck and got them. Now i just gotta find out which wire is pos and neg on the factory pigtail too. Geez what a nightmare haha
Does this work with high beams also? Like when you turn high beam on fog stays on too?Nah man, I just wired up one relay. The power goes to my fog wiring harness when parking lights are enabled.
Yes. The switch is only supplied power when the parking lights come on. They can be used with low and high beams.Does this work with high beams also? Like when you turn high beam on fog stays on too?
