sure it will, you have to write in a song title before you burn your disk.MuskyHunter said:The head unit will not even display song titles of MP3's burned onto disc.
I was going too say that it shows if its burned in. I know it does on my audio books.Timmyo2L said:sure it will, you have to write in a song title before you burn your disk.
thanks for the quick replys!!!
Are you creating an audio CD by converting MP3s or are you creating an MP3 CD that contains actual .mp3 files? An audio CD won't have any audio tags unless the software and head unit support CD-Text.MuskyHunter said:I've been using Nero 7 for burning as well as Exact Audio Copy. The file info is pulled down from the internet database just fine, but once burned onto disc the song info is not carried over. Are you manually entering this information and where?
I first rip all my songs to mp3. Then when later inspired, I burn a compilation onto disc. I create a datadisc , which might be the problem. If I remember it right, if I burned the compilation as an audio disc, I couldn't add as many files as with a data disc. I'll have to try burning it as an audio disc again to see if this is the case.Yahooligan said:Are you creating an audio CD by converting MP3s or are you creating an MP3 CD that contains actual .mp3 files? An audio CD won't have any audio tags unless the software and head unit support CD-Text.
Copying MP3s directly to a CD and playing them in an MP3-capable head unit will display the ID3 tag data on the display.
I suspect you're creating an audio CD and not an MP3 CD.
Dang, thats too much work.Timmyo2L said:I use nero also. I am buring to an "audio cd" and I change the tags manually if I have to under the "properties" button.
Nope, other way around. A data disk with MP3 files is the way to go, if the head unit isn't displaying the song title then you may want to try cycling through the display modes as it may be set to show track/song number. The manual should cover the different display modes, my '05 doesn't play MP3s but does support CD-Text and that should work the same way. I just don't recall which button cycles through the modes.MuskyHunter said:I first rip all my songs to mp3. Then when later inspired, I burn a compilation onto disc. I create a datadisc , which might be the problem. If I remember it right, if I burned the compilation as an audio disc, I couldn't add as many files as with a data disc. I'll have to try burning it as an audio disc again to see if this is the case.
So, if I understand you, burning as an audio disc and not a data disc will put in the song tags?
