ok, heres what it did. i screwed the flap to the fender flare with 4-6 screws. i had to make that bracket out of plastic and i screwed it to the flare as well then screwed the mud flap to it so the mud flap has some suport. If i screwed the flap to the flare and then to the fender liner of the truck i wouldnt be able to use the utility door for anything. The bracket is just cut from some random plastic i had laying around. It is pretty thick and strong so it doesnt bend and stuff. if you need some more detailed pics just ask!
