SO the family and I finally got to go camping with the Titan. We previously had a VW touareg (V10 TDI) and I was curious how the titan would compare. Our trip was a 2.5 hr drive to Bodega Bay CA (where they filmed 'The Birds'). We go almost every year so I knew the route and it has very miner hills (mostly freeway) so I thought it was a great shakedown cruise since I had never towed with the Titan before.
The truck has 167k on it with No Fear package - so 6 inch lift with 17inch/35 wheels. I did change all fluids and when I flushed the transmission I also added another cooler up front. New bilstein shocks with airlift helper bags should keep the ride straight and I use a blue ox WDH for my 25ft trailer (trailer weight is under 6500lbs)
Here are my humble observations:
Even with a lift the titan was very stable at speed and around corners. The shorter wheelbase of the Touareg meant the it got pushed around by the trailer. I worried about the tall tires moving around but it was only bad when we had very high wind headed home - that would have been bad in any vehicle. It was relaxing to not have to grab steering wheel every time you go by a semi.
I got it nice and level with the helper bags at 58psi and my tongue weight at about 800lbs (measure with tongue scale). My trailer carries water in the back but i was filling up at the site so that helped keep weight on the tongue. I do not have the big tow package but added the mirrors, a bigger diff cover, addt'l trans cooler and trailer brake so everything but the lower gears. It had a little bounce to it but nothing unnerving.
Braking and Acceleration were adequate. I did miss the power of the v10 diesel though...
But revving the titan up and I didn't have any issues with power (other issues explained later)
Gas mileage sucked.... I was getting 8-9mpg compared to the 13mpg from the Touareg. I am never one to nickel and dime with mpg and gas prices. I would drive whatever I want even if gas was $10 a gallon because I enjoy cars and driving. Still sucks but I expected it.
I loved having the Bully Dog tuner to monitor temps. It feels good to know what is going on as you drive.
I had the AC R134a flushed and refilled?! Wow, what a difference. Super ice cold AC- couldn't even run it past 3-4 clicks.
I LOVED having a truck bed for all the sandy stuff. Made packing and unloading waaaay nicer.
So now the bads.....
Anti-pinch windows suck.... Every time we roll them up it bounces down - drove my wife nuts. I do have those window blades in track so I guess they will have to come out. I wish there was wire to snip or something to kill that feature.
VERY LOUD!!!! I have an Airraid intake and apparently a flowmaster 40 series muffler (previous owner). Intake is fine since it stays quiet until you gas it. I loved the muffler around town but 2+ hours at 55mph.. UGH. That is being swapped out for a magnaflow immediately.
My biggest problem that i need help with is overheating (engine and transmission)
So I did a full fluid change and added the additional transmission cooler but I still had temps of 190+ just cruising at highway speed. Even hit 204 going up the big hills in 92 degree heat. WTF? I need to double check I have enough fluid but It seemed ok. Dip stick was hard to read when you add fluid - guess i need to wait 20 minutes after adding fluid since it was all over the stick.
Could overfilling it lead to high temps? It is hard to tell with the flush/drain method and adding additional coolers but I swear I added enough or too much.
The engine temp was around the same 190+ but hit 204 regularly and even 230 on the big hill. I have a 180 thermostat, new stock radiator and new coolant. Could the trans temp issue affect engine temp? I was tried every method of low rpms, high rpms, manual shifting, coasting. Problem was that low rpms helped cool the engine but raised trans temp and visa versa.
My only thought on this is my fan clutch is bad. It has resistance when spinning by hand cold but I never heard it really cranking up when hot. I would expect it to sound like a jet if engine temps are 230!!! Could this also affect my trans temp?
Sorry for the long post but I like to hear other experiences and was hoping fellow titaneers could share some insight into my issues. I am headed to Lake Tahoe in 5 weeks and that is will be a much bigger climb in high temps so I need to get this sorted before then.
