1 - 9 of 9 Posts
2019 Pro4X
Hey everyone, been a whIle since I've been around here. I'm not sure if this is the best place to post my question, I'll repost elsewhere if need be.
Yesterday I was out running errands and my girlfriend climbed into the front seat, door opened just fine. When we got to the grocery store, the door wouldn't open. I hit the unlock button on the drivers door, and the actual lock seemed to try to unlock, but wouldn't get there. The unlock button on passenger side and on my FOB both do the same thing. I can't manually unlock it either. It seems to be catching on something but I can't see anything. Anyone else have/had this problem? Thanks in advance!
-Tristan
Had this problem in my old 2011 Murano. But it would unlock manually from the inside, or by key from the outside. It was a pain the pull the key out of the fob to get into the car. The keyless entry part of the fob and the switch inside would not work. Ended up being an actuator in the door. Dealership replaced it. Sometimes they just get bound up or need the cables greased, etc.. Mine was dead.
2019 Pro4X
Thanks for your reply! Did yours respond to the unlock button being pressed? Like the switch trying to unlock, but just physically couldn't? I am just under the mindset that there's something physically impeding the locking mechanism from moving enough to actually unlock it.
Sorry if my terminology is wrong, not terribly auto savvy.
No it would not respond to the powered rocker switch in the car, or the fob button from outside. Inside the car I had to use my fingers to push the little knob/lever on the door to the open position, the part you see move when you engage the power door lock. Basically no power lock, became a manual lock. From outside the car only the key opened the door.
I was hoping it was just a kinked up cable because it was trying to open, but would not. Turned out to be the little motor which had little cables attached to it.
-Tristan
-Tristan
Hi Tristan
I have a 2021 Titan and the same thing happened to my wife and I
200 miles on the vehicle, so back to dealer to have it repaired. Might end up having a recall??
I am having this same issue with my wife's 2012 Armada. The unlock feature whether fob or door makes the lever "try" to unlock but it will not unlock. And you can't move it with your finger either. Seems like it's physically impeded for some reason.
This is the first post I can find online so I'm hoping you found a solution and can share.
Thanks!
-Tristan
Wondering if you found anything out Tristan? Thanks!
2019 Pro4X
Hey, sorry I never replied, I actually haven't been in this site in a few years. My Titan was totaled and I kinda just stopped showing up. Just so happened to get back in another Titan about a week ago and found my way back here. I did get it resolved, but i just had my mechanic replace the actuator. I can't remember what he said about what was wrong with it, just that it wasn't worth fixing, better to just replace it. Did my driver's side too just to be safe. Any luck with yours?
1 - 9 of 9 Posts
