Hey guys, wanted to share the changes im currently making on the T. Been planning for a while how I want to set everything up and after many conversations with Greg at PRG and some other shops, things are starting.
I'm starting with the suspension and tires and after that will move on to some things for a little more performance, then finally onto the interior for better sound, etc.
For this round I have ordered the following:
Nitto Ridge Grapplers in a 305/70r17 size - Already installed
Max Trac 4 inch spindle with the longer brake lines for the front
Radflo 2.0 external reservoir rear shocks
C-10 Deavers
PRG Adjustable height shackles for the rear
Next round will be:
Icon coil overs up front
Air bumps for the front - as i'm gonna be using the stock LCA's for now
Right now im currently running Bilstein 5100's all the way around and while their ok, im looking for a little more performance when we go down south to Glamis and Pismo.
I have the Nitto's installed now and because I have no lift I had to remove the black air dam up front and trim a little around the pinch weld to give clearance until the lift comes in. The Ridge Grapplers are great so far. Extremely quiet tire considering how aggressive the tread is.
Will post some pictures when it finally stops raining enough to stand outside.
C-10 Deavers
Next round will be:
