Mysterious "clunk/clang" in front end
3050 Views 9 Replies 7 Participants Last post by  aford89
Hey guys,
Ever since I have put the lift kit on, I have had this "clunk". It has slowly gotten louder and louder, and is driving me insane now.
As far as lift goes, it's a Pro Comp 6" Lift, PRG Endlinks, MX6 Coilovers for the the front end...
Here are two clips of the noise:
First video you can't really hear it until the end...
Any help/ideas are appreciated...
1 - 10 of 10 Posts
After almost two years I finally figured mine out...unfortunately its quite hard to tell without a quick teardown, but my problem was my LCA shock tabs eventually wearing down and causing a minute gap, thus every time the shock had motion, the clunk...if you have a free day take a look there and check for damaged ball joints too while you're at it...
*and if you haven't already considered some LCA spacers from Greg, may want to look into that too...
Reactions: 1
Lube the swaybar bushings.
Hard to tell from the vid if it's same issue I had...BUT...my swaybar was binding in the bushings, after I put on my ProComp 6" lift.
I removed the brackets, lubed the bushings, and reinstalled...and it's smoother and quieter than ever.
- Brian
Reactions: 1
Ok, will try and check that out soon. What's the benefit of the LCA spacers?
- Brian
Even after putting brand new PRG Endlinks, the noise still occurs. Unless what I am thinking of is something different than what you are telling me to do. lol
Yeah, I did the same...but I'm taking about the bushings...the D-shaped ones that hold the swaybar to the chassis.
See here for pics:
http://www.titantalk.com/forums/titan-suspension/108651-aftermarket-sway-bar-bushings.html <-- TitanTalk thread with pics...
- Brian
See here for pics:
- Brian
Ok thanks man. :) I'll talk to my Dad about this, and go from there...
Perhaps you could eliminate the sway bar from the equation by temporarily removing it.
Reactions: 1
See here for pics:
- Brian
Ditto on this. Every winter my Armada does the same thing so I spray some PB blaster in there and it goes away until next year.
Just tell household 6 that the coilovers are shot, and buy new ones. 10 bucks says the noise goes away!
digging and old one up here but did you ever figure this out? i just put my PC stage 1 on and i have clanking driving my insane, i dont have my sway bar back on yet waiting for my new endlinks so mines not the sway bar
1 - 10 of 10 Posts
