Nakamichi SoundSpace 8 Home Theater Music System, Aurora, IL
This is new in the box, never installed. Still in plastic...
Asking $800/obo, local p/u is Aurora, IL 60502 and I can ship.
I accept Cash or PayPal
The SoundSpace 8 represents a clear departure from conventional audio component design. Compact and streamlined, the system occupies a minimum of space and conforms with today's contemporary interiors. The main system unit, satellite speakers and subwoofer, can be positioned almost anywhere that's convenient; a desk, bookshelf or even floor. Both main system unit and satellite speakers can even be wall-mounted to further save space. SoundSpace 8's remarkable design allows you to economize on space without compromising on sound.
By combining all necessary functions in one easy to assemble compact system, extraordinary sound can be yours in just a matter of minutes. Due to its user-friendly control panel, operation is a breeze.
Despite its small size, SoundSpace 8 delivers the concert hall experience and conveys the orchestra's realism, atmosphere and presence all while complementing your living environment. Never before could you expect such extraordinary sound from a system so compact.
Features and Specifications:
Main System Unit
CD Changer/Control Amplifier Section
CD Player 5-disc MusicBank System
D/A Converter 20-bit Dual D/A Converter with 8-times oversampling digital filter
Frequency Response 5 - 20,000 Hz ± 0.5 dB
Total Harmonic Distortion 0.005% or less (1kHz, 0 dB)
Signal-to-Noise Ratio Better than 95 dB (A-weighted, input shorted)
Dynamic Range Better than 95 dB
Channel Separation Better than 90 dB (input shorted)
Continuous sine wave power output Satellite speakers: 10 W x 2 Subwoofer: 20W
Total Harmonic Distortion Less than 0.1% (1 W)
Inputs 3 (MD, Tape, Aux)
Outputs 2 (L/R channels)
Recording Outputs 2 (MD, Tape)
Optical Digital Output 660 nm, - 18 dBm
Tone Controls
Bass 20 Hz ±10 dB
Midrange 1 kHz ±10 dB
Treble 20 kHz ±10 dB
Loudness 100 Hz +7 dB / 10 kHz +5 dB
AM/FM Tuner Section
FM Section (All RF levels in microvolts given re: 75-ohm antenna input. Modulation: Mono 100%, Stereo Pilot: 10%, Stereo Audio Signal: 90%)
Frequency Range 87.5 - 107.9 MHz in 200-kHz steps
IHF Usable Sensitivity 14 dBf/2.7 µV (mono, IHF)
50-dB Quieting Sensitivity 22 dBf/6.9 µV (mono)
Mono Better than 72 dB at 65 dBf
Stereo Better than 68 dB at 65 dBf
Frequency Response 30-15,000 Hz +1, -3 dB
Mono Less than 0.4% (1 kHz)
Stereo Less than 0.6% (1 kHz)
Stereo Separation Better than 40 dB (1 kHz)
FM Presets 20
AM Section (Modulation: 400 Hz, 30 %)
Frequency Range 530 - 1710 kHz in 10-kHz steps
Sensitivity 55 dB µ/m
Signal-to-Noise Ratio Better than 50 dB (90 dBµ/m)
Total Harmonic Distortion Less than 1% (90 dBµ/m)
AM Presets 10
Satellite Speaker
Enclosure 2 - Way Sealed Type
Speaker Unit
Midrange Driver 5 cm Round Cone x 2 Magnetic-Shielded Type
Tweeter 2.5 cm Semi-Dome Magnetic-Shielded Type
Subwoofer System with Built-in Amplifiers
Enclosure Bandpass Type
Speaker Unit
Woofer Driver 16 cm Round Cone Magnetic-Shielded Type
Remote Control Unit (Main and Sub Remote Control Unit)
Principle Infrared Pulse System
Power Supply DC 3 V (1.5 V x 2)
Power Source AC 110 - 120V or
Power Consumption 68 W maximum
Dimensions
Main System Unit 15-3/16 (W) x 7-5/16 (H) x 4-5/16 (D) inches
Satellite Speakers (ea.) 3-1/8 (W) x 7-5/16 (H) x 3-15/16 (D) inches
Subwoofer System with Built-in Amplifiers 9-1/16 (W) x 20-1/16 (H) x 9-5/8 (D) inches
Main Remote Control 2-3/16 (W) x 3/4 (H) x 7-3/16 (D) inches
Sub Remote Control 1-15/16 (W) x 1 (H) x 4-15/16 (D) inches
Nice Stereo!!! I bet that thing sound's incredible! Good luck with your sale! :)
Thanks...It really is nice.
When we bought it, we thought it would fit in a certain place and it does not. A friend has the same on and I think it is around 5 years old and still sounds brand new. New it was $14XX, so this is a great price. If the economy was not so bad, we would just keep it.
