tommy1993 said:
Everytime I try to find an address or location it always tells me the distance is too far. Why is this happening.
I'm not quite sure what you are doing here but you can adjust the distance you want too see, and the distance you want the warning too sound. I've set routing four states away with no problems. Mine is OEM, if thats what you have you'll have a Nav. manual with your truck. You just need too sit in your driveway and play with it. Once you get it figured out it's easy too use. Thats what I did. After having Nav. I'll never buy a vehicle again without it.
Perhaps your navigation system has gone blind......... :dunno:
I agree with Mr. Datsun. I like the OEM NAV and will not be without one again! But as mentioned, sitting with the manual is a requirement....at least until you get used to it.
I would check with the dealer. I programmed my OEM Nav to go from Nevada to Illinois.
