I HATE not being able to use the navigation while moving. To correct this Nissan faux pas, I want to put a switch on the VSS wire of the navigation unit, but I'm not sure if I have the correct wire. On a different thread, baseballfanz said that it is the wire: "white with red...pin 28 on the M95 plug" but I don't know where the M95 plug is?? So, attached is a picture of the Nav unit backside. I want to put a switch on the W/R wire connected to the harness but don't know if that is correct.
A better option would be to splice into this wire under the display panel. Does anyone know which wire to splice??? Attached picture shows a possible wire to the Nav unit. Pictures would be much appreciated.
