Need advice from Proffesional Detailers!!!!
2002 Views 8 Replies 6 Participants Last post by  americanskiff
A freind of mine got a 2012 or 2011(cant remeber the year) 302 Boss mustang. Problem is there is over spray on the car....he clay barred the overspray off the painted areas and glass, but the problem is the car has alot of vinyl black stripes on it. All down the side and a large one on the hood. They also have overspray on them. We work at a body shop so the overspray may have come from here, or from Ford....not sure which.
I need some advice from someone that knows how to remove overspray from large vinyl decals without damaging them....
Appreciate any tips...
1 - 9 of 9 Posts
try lacquer thinner but i would test it on a small area first
No one else at the body shop canfigure this one out? They use paint every day. I would only guess that PREPSOL or denatured alcohol would do it. But that is only a guess.
lacquer thinner will discolor and maybe even melt the vinyl.
Prep sol....will discolor the vinyl. Have to be careful with liquid chemicals cause the vinyl can absorb it.
Try Meguiars "overspray clay." It's designed to take off the overspray. Sears: Online department store featuring appliances, tools, fitness equipment and more
Yea I thought about using a clay bar but really not sure if it will scratch the black vinyl or not.
Im hoping someone has come across this problem before and removed overspray with success
You're going to have to try a few different things in small areas and see what makes it give up
First I'd try high presure hot water with a fine fan tip and be careful, watch the edges don't peel.... usually if you go slow and steady you can get a bunch off that way.
Gonna be a tough one either way.
Reactions: 2
Give what Skyboi said a shot. He knows his stuff! You may want to try hairspray. It may have just enough solvents in it to remove the paint without damaging the vinyl.
However, I have a feeling your friend is gonna need to replace the stripes to make it look good. That's what I would do...
Reactions: 2
Thats what I suggested also, to replace it.
Thanks for the advice everyone.
1 - 9 of 9 Posts
