1 - 3 of 3 Posts
So I have a 08 2wd and I'm looking to put a leveling kit on it and some bigger tires. From what I've read so far it sounds like the Prg kits are some of the best quality but I'm not sure what size I need to go with. Im also looking at the nitto trail grapplers and I would like to try to get 35's on it but not sure if it's even possible. I plan on keeping the stock wheels on the truck. If anyone has tire size and leveling kit advice it would be much appreciated.
2" leveling kit is what you need. 35's should fit with stock wheels, but you will probably have to do a pinch weld mod to keep it from rubbing . you can search pwm. i ran this setup for a year with no problems.
I have a 2008 CC 4x4 with a prg 1.5 leveling kit in the front and nothing in the back. I have the 275 70 18. I really like the tires I just wish they were a tad bigger. They looked awesome prior to the leveling kit but after they look a bit on the small side. So id def say bigger the better ha.
1 - 3 of 3 Posts
