Need advice with a new audio system
797 7
Well I am planning to go all out on a new audio system! My goals are to get as much bass without comprimising space(I don't want to have to lift a seat up). I was leaning towards a Tech12volts custom box and two JL audio 10W3v3-8 subs(Im guessing thats as good as im going to get with only 6 inches of mounting depth). I am really not sure what kind of deck or amp i should get to get the most out of the subs:lookaroun ? The component speakers are the rockford Fosgate system so im sure they are good enough:rockon ! Just any advice would be great, or an idea for another place in the titan to put another sub!!
Thanks
1 - 8 of 8 Posts
Discussion Starter · #2 ·
could i get 4 10" JL's under the seat of a CC?
and the stock speakers are all crap, you would be much better off upgrading those and getting a good set of 10s. I would suggest the boston G1 or sundown SD-1s instead of the overpriced but decent W3s
Just upgrading the stock spkrs. without amps is a waste of money, and in most cases will sound worse unless they are 2 ohm impedence.
wow really, I have heard so many good things about JL, and I have owned some kickers, and honestly i was not impressed(a lot of distortion), but what about the amp? what should i get
1 - 8 of 8 Posts
