1 - 2 of 2 Posts
Does ANYONE know the bolt size for the three Torx bolts that attach the mirrors to the door?? I purchased a set of OEM mirrors, but they did not come with hardware. I have ordered the left and right mounting plates, but it doesn't look like those include the bolts either. I would feel much better knowing I had the exact size/pattern bolt, even better if it was the actual OEM bolts.
ALSO, is anyone familiar with the wiring harness and have a guide as to which wire goes to what? I have the LE Non-BT power-folding mirrors with turn signal and puddle lamps now, and am looking to steal the turn signal and puddle lamp wire to use to power a fabbed morimoto switchback led strip and rigged up puddle lamp assembly that I am going to work into these housings. I'd also be curious about the power folding wire line, if I had that as well I could theoretically switch on either the switchback "normal" on mode and/or the puddle lights just by pressing "open" on my power mirror equipped driver's side door panel switch.
Any assistance is much appreciated!
1 - 2 of 2 Posts
