1 - 6 of 6 Posts
i did a little searching but wanted to ask anyway, just to be sure.
2018 Titan
on acceleration fan is very loud...sounds like a dump truck.
at cruising speeds it seems to quiet down.
turn the ac off and it goes away completely.
is this just a bad fan clutch?
2017 Nissan Titan S - Plain White
last night, the fan engaged with or without the AC on...it seems to be random, but much more likely to lock up if the ac is on. it's gotta be a fan clutch right?
most likely. if it sounds like the garbage truck it is. The titan Has an electro-viscous fan, I suspect they have a lot of bad electronic module and they end up engaging randomly. mine broke not long after the engine replacement… figure they damaged it doing the job… but then again they might just be el cheapo cluch fans.
If you still have warranty time for a dealer visit.
1 - 6 of 6 Posts
