Hey Im new here and Im looking for suggestions. I recently bought my Titan and want to put a leveling kit on, I dont know what size though. Does anyone know whats best? 2" 2.5" or a 3" kit for the front to equal the rear? I have and 04 titan se 2wd
Either the NCD or PRG will work fine...Good thing about the PRG is it comes with upgraded bumpstops. With the NCD kit you will need to goto Auto Zone order yourself some Energy susopension stops. Part # 9.9101R they are $20 and you will have them in a few days.
As for the Rough COuntry 3" kit, its pretty nice and come with everything to go 3". Though I dont think its been around long enough for people to really use it alot. I have only seen a few people use it, most have good things to say about it. Some have nightmare stories...
With the PRG and NCD 2.5" kit you will be almost completely level. The 3" kit will make it completely level if your shocks/struts are in good shape. but if you have stock shocks/struts it will still be a little en even till you get good suspension parts under there.
With your truck parked on a level surface, grab a tape measure and measure the distance from the ground to the bottom of your fender. Align the tape measure over the hub. This will give you an idea of the height difference between the rear and front.
Right now, with the info you have above I am guessing a 2" block will level out your truck.
Go with PRG. I did and couldn't be happier. Greg will be more than helpful. I put all new shocks/struts on when I did this and it rides great. I only went with a 2" level on the front because I like a the look of a little rake----it came out perfect for me. So If you want exactly level, do the 2.5" kit.
My signature pick is before the level, I'm waiting for a nice day and looking for a cool spot to take pics of after product. Plus I'm waiting on new tires also.
i have the leveling kit that I just took off my truck, I only ran it for abot three months. $100.00 and it comes with the 3" spacers up front and a pair of 1" cst blocks for the rear, you'll need some new u-bolts they were galled up so I had to cut them off. I'm right down the road from you, here is how it set my truck up.
