Does anyone know the color of the headlight wire (low beam) coming from the combination switch to the BCM? For a 2006 if it matters.
I know the wire colors directly from the headlight to the IPDM... I need one closer to the dash preferably.
I've been looking through the service manual at the wiring diagrams for a 2011, but the wire colors should be the same, at least from what I can tell. The diagrams are slightly confusing.
If you don't know the color... but you have a service manual. It's in the EXL (exterior lighting), pages 79-80 (for a 2011 manual, but should be close if it's another year), connectors M18 and M28.
I think I have narrowed it down to a few possibilities. It says headlight 1 (real helpful, they couldn't do left/right?) is output 5, and headlight 2 is output 4. That would be terminals 8 & 9 for connector M28.
Another possibility is terminal 40 on connector M18, which is named 'CAN-L'. L as in low beam possibly?
Or it could be none of those...
Also an easier question... I need to know the polarity (+ or -) of the parking light circuit and the polarity of the headlight circuit. I believe the parking light circuit is positive, but I need confirmation? And the headlight circuit I assume is positive as well?
Any help would be greatly appreciated.
