Here is what I have, 2014 CC, SL, with Rockford system, It sounds like I have a couple of blown speakers in my rear doors
1, do I replace all my speakers and will they work okay with existing head unit and amp.
2, do I replace entire system head unit and speakers, and amp, problem with this I will lose use of my back up camera, because every head unit I have looked at in Crutchfield says they wont work with existing rear camera
I say use it as your free pass to upgrade the whole thing... On that note, however, I have never had a stock stereo system that sounded this good.. and I don't even have the RF package.
I'm not sure what head units you've been looking at, but, I've got the same truck. 14 that had the RF system. I've got a Kenwood deck that I still have the rear camera hooked up and works just fine. I should be home later today as long as my flight doesn't get screwed up and I will post up the model of it. Talk to Tech and tell him what you've got going on. He's the one I got my stuff through.
Sent from my 2PS64 using Tapatalk
The Rockford system is OK, just not terribly good as auto audio goes. Have had two Titans with Rockford, replaced HUs in both.
As stated above: simpliest solution, if in fact speakers are blown, just replace the speakers. They are 2 ohm impedance.
Backup camera will work with new HU. There is an adapter cable available from AXXESS that makes it plug and play (used one on my '13 Titan). Be advised that you lose the 'grid lines' when doing this. Also, the OEM camera is supplied 6vdc by the the Nissan HU, the AXXESS adapter applies 12vdc - had no problem using the AXXESS cable on my 13 Titan. However, if you are nervous about using the AXXESS cable as is you can add a 12v to 6v converter IC (about $2.00 at Fry's or similar) to the wiring. I did this on my presently owned 2016 Frontier.
