1 - 9 of 9 Posts
Ok I need all you wiring people's or nitrous head's help I need to know where to get correct readings off the throttle position sensor and also need to be able to find the wire to get correct rpms. I'm wiring in a nitrous window switch and am lost right now so if I can get any help on what to hook it up to or a wiring diagram would be a big help
Discussion Starter #2
Bump bump bump need help guys or gals
...08 Pro4X...
I don't think anyone has had much success with nitrous on our trucks...:dunno:
Ofivecc had nitrous on his truck. He roams from tine to time so send him a pm he should be able to help you out, or hit up toomnymods he should be able to help you out as well.
Bump bump I just need to know what wire to hook it up to on the throttle body, so I can read WOT please anyone that can help!!!
Banned
Dude all the fastest Titans have been on the GAS(NOS)!
The Head
Rb'sTitan
Toomnymoods
Ofivecc
Ken(don't remember forum name)
alexk1031 the wide open throttle switch needs to be mounted on the gas pedal, you will also have the get a tach pickup. I will post that part no. tonight.
When I get home for Christmas I will install my relays and my arming switch and my install will be complete! Then Danblp can tune!
Discussion Starter #8
The Head
Rb'sTitan
Toomnymoods
Ofivecc
Well I pm'd toomny and ofive but they never responded. But I'm not using a microswitch... I'm using
Digital Two stage rpm window switch with built in TPS switch for nitrous oxide. Nitrous oxide rpm window switch at discounted prices. Controls two stages of nitrous oxide. - Digital Two stage rpm window switch with built in TPS switch for nitrous
So I need to hook it to the throttle sensor and then to the tach but don't know what wires I need to splice into
Banned
The tach pickup I used is a MSD GMR PICKUP PN-8918, it hooks up to white wire with blue stripe on coilpack for no.1 cy.
1 - 9 of 9 Posts
