So yesterday I installed a JVC double din HU. My truck has the stock fosgate system. I used the correct harness for the install, but for some reason, now when I turn the truck off there's a pop from the speakers. I'm guessing it either has something to do with the remote wire, or the ground. Any advise from fellow members would be greatly appreciated.
Thanks in advance, Mike.
Which harness did you use and what year model truck is it???
Your harness should be a 70-7551. Make sure it's not a 70-7550.
It should have RCA connectors on it to connect to the radio
I have heard some people having to use a resistor on the turn on lead to get rid of the pop. tech12 can tell you what you need
