I have a 6" Pro-Comp lift with 4" Fabtech Blocks in the rear.
The rear axel and tires seem to be pretty well set back in the wheel wells.
I am worried that when I put the PRG Traction bars on they will prevent the suspension from stroking towards the center of the wheel well. Thus causing the tire to strike and rub the rear of the wheel well.
If the wheel Strokes Straight up it will hit the rear of the wheel well.
Is this a valid concern?
Having trouble getting ahold of PRG.
I will get pics ASAP.
Like to hear any and all thoughts you all might have on this.
Also if anyone else experienced this.
Thanks.
I think the first question should be why is the rear axle so far back?
I'd settle that before anything else...
Talked to Greg about that and he says that it is normal for the axel to be further back.
Did he mean after installing 4" blocks?
He Sold me the blocks. so yes, he knew what i used.
