I just bought some jba shorties and people are now telling I'm gonna have to have pipe made to get them to connect to my exhaust. Should I cancel and get longtubes?
The shorties are designed to allow you to put the front set of catalytic converters back into the exhaust system. Those of us that have to pass emissions test need all four sets of catalytic converters. So log tube headers work work for us. The install of shorties is more difficult as you have to mate up to them with a welded set of cats, not a bolt on set.
JBA headers are designed to have catalytic converters installed in the OEM primary cat position then you have to flange the exit to connect to the B pipe. If you do not have emission restrictions, you can eliminate the forward cat all together, weld on pipe to meet the length it takes to connect to the flanged B pipe. The only problem you will run into is that the stock B pipe has the O2 sensor in front of the secondary cats and your Titan will throw a catalyst system under threshold SES code. You will need O2 foulers, Up Rev tuning, Berk B pipes, or customize your own and swap the cat/O2 locations.
Nissan Titan Forum
Nissan Titan Talk Forum is a community for truck owners to discuss the Titan Cummins, Warrior, Midnight Edition and more!
