Hey guys, I'm getting fed up with this thing. So when i bought this truck, it barely managed to get 9mpg, the exhaust was completely hacked to sh*t (see here: Code P1283.) So I set out to get the exhaust fixed, and get rid of any leaks. So i bought some JBA LT's from Cajun, Uprev from Joe, stock catted b-pipes, and the stock catback. Installed it all with OEM Nissan gaskets, and torqued everything to spec.
I fire it up, and it was better, but still had leaks, So Jeff told me to loosen everything up, and told me the sequence best to torque it all back down with. So i did, and it got better. You couldn't hear it at idle any more, but you could here it while driving or under load.
So Jeff recommended that the stock b-pipe flanges might be warped, as they are thin and are prone to warping when you torque them down. So i bought the 2.5" cajun catless b-pipes.
Been a few weeks now, and I swear i can still hear it. Now i do have a hearing problem, so its hard to be 100%. It might be injector ticks, header pings, or an exhaust leak. All i know is that since it has the stock muffler, its very quiet and i can here everything that comes from the motor.
I cant figure out how to make it stop. Whatever the sound may be, it makes me cringe every time i drive it. Im so close to pulling it all out and using high temp RTV on the entire system with no gaskets. Also debating on selling it and letting it be someone elses problem.
Any other ideas guys?
