1 - 2 of 2 Posts
I installed a new double din Pioneer radio into the factory double din spot using the factory brackets as another thread indicated. It’s the FH-700BS. The brackets fit perfectly onto the unit when I placed them at the holes that felt it naturally fit in. There’s more holes on the sides of the unit and I was wondering if anyone had a pic of which holes they used to bring it out flush with the dash. It seems I put the brackets as far back as possible but I hope not. Did I miss something?
Depending on how much 'forward displacement' you need to get the look you want, you could use some spacers between the mounting bracket and the mounting points in the dash. (you may need longer mounting screws).
1 - 2 of 2 Posts
