NEW PRODUCT RELEASE - NP62800 Tube Step Rocker
Our newly designed Tube Step style rocker steps for the H61L Titan XD are built from 2.0" x .188" tubing and feature precision bent tube step w/ non-skid reverse dimpled die step plate. They are built to use as a step for easy cab access. These rockers provide protection from the bottom and from the side as well. Our mounting system utilizes 3/16" thick plate brackets that are fully welded and gusseted to the main bar and install to the body via 4 mounting points per side. Required hardware is included with the rockers as well. Skids are finished in our factory matching Nissan metallic gray or semi-gloss black powdercoat.
Fits 2016 Nissan Titan XD 2/4WD.
Part # NP62800 Price $489.95
https://calmini.com/detail.php?b=1&m=50&t=6&p=1268&n=
