The Titan would probably benefit from being able to adjust or increase the Auto Transmission Line-Level using a programmer? It would be ideal to measure (real-time) line pressure as well.
Or a separate unit could be made, like the ALC II was developed for the 90-’96 Nissan 300ZX by HKS, it is a plug-in interface with factory A/T Control Unit of the computer controlled automatic transmission. The ALC II was designed to maintain constant line pressure within the transmission for consistent, crisp high performance shifting. Should the pressure begin to drop within the transmission, the ALC II will signal the factory A/T Control Unit to increase line pressure and maintain it at that level.
