1 - 13 of 13 Posts
Been searching and searching and I dont know if I'm doing it right. So please bare with me. :eek:
Has anyone confirmed that the Nismo CAI and Nismo Cat-Back fits the 2008 Titans? My dealership has the CAI in stock and I would have to special order the exhaust system.
Anything?
Thanks
Yes the exhaust is for the 04 to 08's
Item Description:
Add Horsepower, Torque and a Throaty Tone to your Nissan Titan with a 50-state legal Nismo Cat Back Exhaust System
Item Details:
True Dual with Easy installation (no cutting or welding)
Refined throaty V-8 sound ? under 95 dBA as tested per SAE J1169
11 HP and 8.0 lb-ft increase at the rear wheels
Dual 2.25? 409 stainless steel inlet pipes
Dual 6? 304 stainless steel ceramic core mufflers
4? Dual wall polished tip 304 stainless steel (NISMO etched on rear tip)
2.25? 3 BOLT connector flanges (no cheap slip fit joints to leak or create alignment issues)
OEM heat shields installed on the inlet pipes for added heat dissipation
Available for 2004-2008 Nissan Titan
hey kili, did the dealer say how long it would take to order? i was thinking about the same exhaust setup. i know someone on clubtitan has it with soundclips, and it sounds pretty dope.
They didnt say. I have to get back with them sooner or later. I'm going to put a decent amount of break-in miles and strap it do a dyno and, get some base numbers before modding.
Anything?
Thanks
I wouldn't buy it from the dealership. They'll want at least 1200-1300. This place has it for $891, and I've seen it for less on E-bay.
Leeparts.com. They are a dealership up north.
I can get it for under $800 from the dealer
Discussion Starter · #11 ·
Thanks!
I finally found a thread where the content has an 08 with the nismo exhaust. that was enough for me to go by on. Worse case scenario is that if the tech can't get the exhaust to fit, then i get my money back.
1 - 13 of 13 Posts
