So I finally got around to installing my Nismo Stat today.
I used a 2011 Titan Service Manual for removal/installation procedures.
Here is a run down of what I did then pics to follow;
STEP 1: Remove front brush guard, I was surprised at how light this thing actually is. Its aluminum too.
STEP 2: Start truck and run heat on high fan setting for 10 seconds.
STEP 3: Open drain plug at the bottom passenger side of the radiator.
STEP 4: At this point it is OK to remove (slowly) the radiator fill cap. While I waited for the antifreeze to drain I started the removal process of the intake so access to the stat housing would be easier to get to.
STEP 5: Once fluid has stopped draining you can proceed with removing the stat housing. I did not remove the hose first as the Service Manual states. This step is unnecessary.
STEP 6: Remove Thermostat with o-ring attached.
STEP 7: Install Nismo Stat with Stant o-ring part number 25283. The wiggle nipple must be at the noon position, you'll see what I'm saying in the pics below.
NOTE: Service Manual suggest putting dish washing soap (dawn) on o-ring, I think its to help hold the stat in place for installation.
STEP 8: Installation in reverse order...your done
P.S. I did line the underside of the stat housing with towels to catch any antifreeze that leaked out which was very little. The Service Manual states to NOT get antifreeze on the belt. Also I used exactly one and a half gallons of 50/50 Prestone to refill the radiator.
While I had the intake off I went ahead and did the Throttle Body screen delete as 06HemiRam did, Thanks!
On to the pics:
On to the pics:
