Having an issue regarding the electrical system.
The vehicle locks itself after the windows go down for no reason.
Windows (both) go down at random. The backup lights flash and the doors lock automatically.
When you unlock the door, the alarm goes off and lights go off. The alarm has to cycle through before it will stop as you can not turn off the alarm, regardless of what we do.
We purchased and installed a window switch and reflashed the ECU since and it still does the same thing
Please advise a solution
Any help would be greatly appreciated
Best
pops
Your windown rolling down might be with your remote. If you hold down the unlock button it's supposed to roll down the front windows utill you let go of the button. Also if you accidently held onto the remotes lock button while a door wasn't fully closed it caused a bunch of issues on my 08. And had to cycle through some of the functions to get it back to factory specs.
Hope this helps.
