S
static10
·Guest
Here is the number I have for contacting Nissan. Like I said good luck as it does take them a while to get back with you and it was the same answer my dealer had but it is worth a try. They will set up a file on you so when you call back in you do not have to give all your information again. They also assign a customer service rep to work with you. My VIN will be available next week and they just told me to call and I can get. Here is the number.
1-800-647-7261. Use option 7 then use option 4. They will tell you to talk to your dealer but tell them you really would like them to check for you also. Good luck.
