Nissan Titan 07 4x4
1817 Views 5 Replies 4 Participants Last post by  Brabbit
Anyone can be relate with this inssue before, start happening last week.
http://youtu.be/WiRJ_i7x4PM
video was make with car running
Slip light on
ABS light on
Speedometer does not work
4x4 light ON
Sometimes can do not start, I have to put on Neutral to get start, even on neutral wont start,
1 - 6 of 6 Posts
You need to see if it's throwing any codes. If you don't have anything to check it, most autoparts stores can do it. With the codes there are guys on here that can help. It's the first question they usually ask.
Here I took the car to the mechanic last Friday and he has told this, is ground problem with codes ( P1212 - P1610 - P1612 - U1000 - U1001 )
He has told me he has found a loose ground wire in the back of Steering Wheel airbag or some area by the dash not quite sure now, plus I notice the airbag light wont stop flashing
he has check battery fluid level and he had told are all OKEY
but just start happening again
Is your tailpipe broken off?
No everything look just fine!!! Now the shift is on drive mode and i just got the service engine light plus airbag light, im driving and im going to see what happens
Having same issue, spongy brakes, abs slip brake and 4x4 lights on and 4x4 don't work. Did you fix yours or any tips on how to diagnose where a bad connection is?
Sent from my SCH-I545 using Tapatalk
1 - 6 of 6 Posts
