1 - 6 of 6 Posts
Hello guys
iam looking for used Piston rings for my Titan 09 SE , where can buy them , and is there a source that i can get them or a used engine exported from japan,
please help ASAP
Hello guys
please help ASAP
Why would you attempt to reuse rings? Assuming you're rebuilding an engine you shouldn't reuse old/used rings. You could reuse the existing rings if you don't de-glaze/hone the cylinders and put the pistons back in the same cylinder provided you had good compression to start with.
Troll.
Reactions: 05titans
1 - 6 of 6 Posts
