1 - 20 of 258 Posts
Total Auto Performance - Las Vegas, NV
702-979-1577 | 888-244-6166
Hey guys,
I see a lot of threads on TitanTalk asking "Which bilstein shock do I need" or "What is the difference between 5100 & 5125s?" so I decided to put together the end all be all guide so we can have all the part numbers in one place. TAP Auto Parts stocks a huge selection of Bilstein shocks for the Nissan Titan and has the knowledge and experience to make sure you get the correct parts, everytime!
Bilstein 4600's - HD Series
Yellow Shock, Blue Boot
These shocks provide improved handling and stability, without sacrificing ride comfort. They offer super damping ability that makes them ideal for the driver who demands superior performance, while maintaining an exceptional street ride.
These are the classic Bilstein HD shock. While they do not offer height adjustment, they are the best direct OE replacement shocks for the Titan. If on road performance, a good street ride or lowered suspension is what you are looking for, then the Bilstein 4600 HD is the shock for you.
2004-2013 Nissan Titan - Bilstein 4600 Applications
Front - Bilstein 24-197656
2WD Rear - Bilstein 24-185967
4WD Rear - Bilstein 24-116244
Bilstein 5100's
Silver Shock / Black Boot
The Bilstein 5100 series shock absorber is designed specifically to help your Nissan Titan reach its pinnacle in ride performance, while supplying the correct tuning and length for your specific lift. The 5100 for the front of the Nissan Titan is ride height adjustable with the use of multiple snap ring grooves which position the spring seat at different heights. The trucks ride height can be changed anywhere between 0-2.5” depending on model.
The rear shocks are slightly longer then stock and will allow for up to 1" of added lift.
2004-2013 Nissan Titan - Bilstein 5100 Applications
Front - Bilstein 24-197649
2WD Rear - Bilstein 24-186773
4WD Rear - Bilstein 24-186766
Bilstein 5125's
The Bilstein 5125 shock is a universal length 5100 shock for custom lifted applications. These are used on the rear of the Titan for lifted applications taller then 1". As these are universal, they are shipped from Bilstein with 5/8's eyelets, which need to be swapped out with 14mm bushings and eyelets to fit the Titan. The bushing kit runs $25 which includes enough pieces to do both ends of two shocks (the complete rear set)
Suggested Bilstein 5125 Series shocks for Nissan Titan rear based on lift height
2WD Lifted 1-3" or 4WD Lifted 0-2" - Bilstein 33-185552 (Use Bilstein 24-186766)
2WD Lifted 3-5" or 4WD Lifted 2-4" - Bilstein 33-186559
2WD Lifted 5-7" or 4WD Lifted 4-6" - Bilstein 33-185569
Bilstein 5165's
Silver Shock / Zinc Finish
The Bilstein 5165 shock is a universal length 5100 shock for custom lifted applications that also features a remote reservoir for maximum offroad performance and longevity. These are used on the rear of the Titan for lifted applications taller then 1". As these are universal, they are shipped from Bilstein with 5/8's eyelets, which need to be swapped out with 14mm bushings and eyelets to fit the Titan. The bushing kit runs $25 which includes enough pieces to do both ends of two shocks (the complete rear set)
Suggested Bilstein 5165 Series Remote Reservoir shocks for Nissan Titan rear based on lift height
2WD Lifted 2-4" or 4WD Lifted 1-3" - Bilstein 25-187700
2WD Lifted 5-7" or 4WD Lifted 4-6" - Bilstein 25-187731
Bilstein 7100's
Silver Shock / Electroless Nickel with Clear Powdercoat
The Bilstein 7100 Series shock is designed for stock truck and limited buggy race applications as well as prerunner trucks, off-road and sandbuggies and other recreational vehicles. Completely owner rebuildable, The Bilstein 7100 Series shocks come in remote reservoir or standard body with Schrader valve fitments. These are used on the rear of the Titan for lifted applications taller then 1" that need a higher performing offroad shock. These shocks feature Self-Adjusting Deflecting Disc Valving which is customizable. As these are universal they are shipped from Bilstein with 1/2 heims, which need to be swapped out with 14mm.
Custom - Call for your application
TAP Auto 14mm rear bushing conversion kit
Needed for any non Titan specific rear shocks.
But what are those section???
Other Bilstein shock descriptions that members often ask about.
Bilstein 5150 - Universal length shock for custom lifted applications that also features a fixed CrossFlow reservoir - N/A
Bilstein 5160 - Application specific remote reservoir shocks, No Nissan Titan model. (Some lengths will work! Just gotta dig thru)
Bilstein 6100 - Rebuildable offroad race shocks for sand rails, Baja Bugs, sand cars etc.
Bilstein 9100 - Competition level extreme duty, take-apart monotube damper designed specifically for off-road racing.
Bilstein 9300 - BLACKHAWK - Professional off-road race shock technology.
TAP Auto Parts
is the place to get Bilstein shocks. We stock a wide selection and have competitve pricing w/ free shipping!
[email protected]
So the 5100s no longer offer then .5" of lift? its either 0", 1", or 2" ? Also I tried to TT discount code and it didn't work. thanks for this thread btw!
Hey Chas, just want to let you know I got all the parts in for the shocks. Very quick shipping too. Thanks for the help and great customer service.
Discussion Starter #11
Good to hear Renlo! I hope it smooths out the ride for you. Thanks for the business and please let me know if I can be of any future help:hat:
Do you have anything for the Armada? I lowered my 2012 2" all around and need shocks in a major way to get rid of the bouncing. Help please LOL!
Damn looks like I missed out on a damn good deal. $156? :crying:
Sent from AutoGuide.com App
Discussion Starter #14 (Edited)
The shocks for the Titan front will fit on the Armada perfectly. Unfortunately Bilstein does not make anything for the rear of the Armada that is application specific. I could recommend a pair that I think may fit the rear, but Im not sure with the lowered suspension. Best bet is to call Wes at Bilstein and ask him what he would suggest - 858-386-5900
Was a returned set...
Chas, thanks for your help the past few days. its funny that im still looking into installing my fabtech 6" lift but i need the rear shocks and i found this thread that is fairly recent. i think i have read all the treads on this lift (just 6" in particular, not fabtech specific) and you seem to try your best to accommodate us titans, thanks again.
note: this guy is a great help but be sure to do your research before jumoing into things.
So what would you suggest to keep the current ride height, but improve overall on and off road handling? I currently have the procomp 6" lift kit. I would love to remove the tophats up front without effecting the ride height, if possible. It is my daily driver, but I get the itch to go bombing around in the desert and stuff.
1 - 20 of 258 Posts
