I just recently installed a LEDglow kkit and it looks awesome check it out
YouTube - Nissan Titan LEDGlow Kit interior.wmv
Sweet thanks for the good info. I'm soso with cars, but I'm an electrician, so I'm not scared lol. You answered my questions and I'm def leaning towards this one. Thanks again.Yeah the one i got was the 6 piece million color flexible kit its easy to install if i could do it you definitely can i have very limited car skills but i am good with electronics and wiring. I wired my straight to my fuse box into the heated seats fuse section because my titan does not have heated seats and i put the ground right under the passenger seat bolt. I has strobe, slow flash, solid color, and a tone of three diff color flash options and you can change the speed of any pattern from you remote. with it plugged into the heated seat fuse it automatically starts every time i turn on my car. and its very bright i was suprissed how good it works for the price
I gotcha. I got a ton of vampire clips I can just use though. I thought this was for the addition of 2 more led strips. 8 would be perfect for what I have in mind. Thanks again for all the info, man it's a ton of help when you're orderin online.The expandble circut the one under the add to cart button is the fuse thing.
it alllows you to plug the power source into a fuse it looks like this LEDGLOW's Expandable Circuit & 4 Amp Fuse
Does that answer the question and for Nissan titan you need the mini fuse and you will need to go to autzone or wahtever to get a mini ten amp fuse because the ones in are car are to small to go into this add a circuit
