Im sure this has been talked about but I can't find it anywhere. I have a 2012 SV and I want to put Tow Mirrors on it. All the mirrors I find online say they have heat. Will these bolt right up and will the Connection be the same even though I don't have heat?
The difference will be whether you have memory or not. If the mirrors have heat then you will have heated mirrors when you plug them in. They are tied into the rear window defroster.
Note: watch the wire routing when you put them in, if you get it wrong it will cut the wires when you put the windows up.
Higher models have "settings" for different drivers. For example one driver is 6 foot the other is 5'6" you just select which preset you want and it will readjust everything to your specifications.
