1 - 20 of 20 Posts
I wish we had shot some traction video when the Colorado Titan's went off-roading recently. I have the locking rear differential and when I had it locked in I just chugged right up the hill and over anything in my way (except for that one BIG boulder). But there were a couple of guys without the locking rear differential and you could tell they didn't have it. They had to be a bit more creative about approaching certain obstacles.
That showed that the ABLS does work, however...flooring it like that is what you're NOT supposed to do. Light on the throttle works best because you won't overpower the brakes as much and allows power to transfer. It's no locker or real LSD, but an open diff with no traction system at all would have yeilded that sharp red truck digging a hole with its' RR tire and going nowhere. Thanks...great video.
I bet it smells like hot brakes around there!
Banned
Yep! Just throw it in 4WD and floor it! That'll get us non-E-Locker guys up tricky situations lol
Though I noticed after that big boulder, I got two wheels off the ground, the front right, and the back left were off the ground. I was in 4WD and the front right tire woudl spin, but the front left wouldn't...
I recomend a locker or true trac..because as a guy without it, it SUCKS!
That boulder was like a magnet to the Titan! Nice driving. A set of cables on the front tires might have helped also.
Discussion Starter #10
Sorry, My internet went out last night and I'm just getting back on. This guy has some pretty cool video's. There is like 15 and I'm not going to put them all on here. Let's see if this work's. YouTube - WyoTITAN's Channel
Wasn't the white Titan a off road with the E-Locker??
If so why didn't he lock it from the start?? Thats like waiting until you get stuck to lock in 4wd.
Always plan for the worst, prepair and hope for the best.
Discussion Starter #12
That's the way my brother does it, His thang is, "Go as far as you can in 2wd then put it in 4x4" I'm like what if by the time you get as far as you can in 2wd you can't get out in 4x4? He just laugh's. :bangit:
I grew up in Wyoming doing all sorts of stupid things with 4x4 trucks. The Conventional Wisdom was you play in 2hi and shift to 4hi/lo when you get stuck.
Discussion Starter #15
If I'm playing then 2wd yes, If there is no one to pull me out, 4-Hi and spin the b!tch's. :eyebrow:
we always try to c how far we can get in 2wd before we put it in 4wd.
Discussion Starter #17
But you have some-one who can pull you out don't you?
yep always his names warn and ha either 12000lbs or 3000lbs of pulling power depending on what I'm driving that day
The driver and the spotter are both pretty dumb
Shouldve been locked in the first place, both the driver and the spotter should have had common sense not to cut right away as the truck is of course gonna slide sideways on ice, couldve prevented the damage done, the spotter had no idea what he was doing
dude.. the spotter was sittin' there laughing...
pretty sure he scraped his rear tire on that same rock too.
i feel bad for the guy; wonder if he's on TT. i'll sell him my side steps if so. i want some exhaust work done :teethmast
1 - 20 of 20 Posts
