1 - 9 of 9 Posts
If the Nissan Navara pickup decided to go to the gym, lift weights, and consult a personal trainer, we think it would look like the Nissan Titan Warrior concept. The Titan Warrior began as a standard model, but the ride height was raised by about 76mm to 2,070mm. This was done to fit the 37-inch off-road tires mounted on 18-inch matte-finish aluminum wheels. The width was also increased by 76mm on each side.:wink::wink:
As expected, the Titan Warrior was given a suspension worthy of its stature. In front are custom upper and lower control arms with performance ball joints, along with racing-style internal bypass reservoir coilovers. A similar setup is installed on the rear end. Adjusted-length prototype axles were also included, along with a custom sway bar, relocated sway bar brackets, and rear lift blocks and U-bolts.
I'm more of a street truck guy, but I would definitely buy it! $60k of course!!
Reactions: John Alistair
Too bad its just a concept.
plus being so new in the market the prices for any kind of suspension upgrade for the first couple of years is going to be ridiculous! kinda reminds me of the Raptor
If I had the money, I would buy a new 2017 Raptor in a heartbeat.
I would go into debt all over again if this truck does come out and is worthy of its name.
Reactions: honda250xtitan
warrior concept is certainly eye candy. Great marketing scheme, but you'll never see it until some show guru with a bottomless wallet gets the inkling
1 - 9 of 9 Posts
