Yes, you can use a backup camera as you want. First, purchase a license plate mounting unit, you can mount it just above the rear plate (I used two mending plates as extenders such that the camera is not directly on the plate).
Get into the wiring at the taillight and find the wire that supplies 12 volts to the backup lights. Tap into that wire with a signal wire to run to the HU (20 or 22 guage wire is sufficently large) and connect to the HU camera sense wire. You will also need to extend the red and black wire and the video cable from the camera to the rear of the HU. Connect the black wire to ground, the red wire to a switched source of 12 volts (has voltage when the switch key is ON or AUX) and connect the video cable to the camera in on the HU. Set the HU to turn on the camera for positive 12 volts on the sense lead.
When the transmission is switched to reverse the HU will display the camera signal. When the transmission is in a forward gear the HU can be manually set to show the rearview camera signal.
On my Titan there is a factory gromet on the rear cabin (drivers side) wall. I penetrated the center of the gromet and routed the rear camera wiring through that hole. The hole is between the cabin and the bed, looking from underneath is probably the easiest way to see if one is there on your model year.
