When I turn my lights on to drive at night, my center console (radio/clock/temp controls) lights turn off. Is there a way to keep them on when I turn my headlights on? 2012 nissan titan pro-4x with Rockford radio
They shouldn't turn off. First, be sure your dimmer isn't all the way down. But I suspect you have some sort of short or bad ground somewhere.
Thank you, I'll have to checkout the dimmer. I just picked up the truck yesterday. Trying to figure out all of the features
Probably the dimmer if they're on when the lights are off. If they're off all the time there is a fuse near the glove box that controls those lights.
I just had this issue. Turn on my headlights and the radio/climate control lights go off. The tech said it was a ground issue coming from the gauge cluster (said power to dash lights comes from gauge cluster harness. I could replace cluster for $800 or run a work around ground. I decided on the work around and that solved the issue. I will eventually look to replace the cluster, but will look for a higher model cluster since my truck is only an S model.
