1 - 3 of 3 Posts
2008 Titan LE. My A/C no longer increases the speed of the blower motor when I turn the A/C control to max. It used to blow stronger when I turned it to max, now there is no air speed difference between high and max. I tried replacing the blower motor resistor but that made no change.
I would check the new blower motor resistor with by checking the resistance between the pins. The resistor I bought at a parts store does work but the low and 2 setting are about the same. Why idk they put the wrong resistors in it I guess. It could also be the switch its self. Mine broke so it wouldn't actually move peg arm thing that connects the knob to the switch.
Did you use an aftermarket resistor?
1 - 3 of 3 Posts
