1 - 3 of 3 Posts
I've located and tested the fuses for all 3 power outlets in the cab, and they are all fine. I tested the fuse socket themselves, and none of those fuses have any power to them. Everything else works fine. I pulled the fuse block out and noticed there was relays on the back. Could one of those be bad? Do they have anything to do with that?
Not sure if it makes a difference, but some of the 12v outlets are only hot when the key is on
1 - 3 of 3 Posts
