1 - 10 of 10 Posts
2016 Nissan Titan SL XD w/factory tow package.
I have 4-way flashers, turn signals, and brakes. Do not have running lights. I just switched out the trailer lights to LEDs. Tested the LEDs and they are fine. I go to test the running lights and nothing.
I tested with my multimeter, and there is no power coming from the plug for the running lights. All other pins check out fine for both the 4-pin plug and the 7-pin plug, so I'm guessing I popped a fuse.
My problem is: I've gone through the owner's manual, and have looked at the three locations for fuses (2 in engine compartment, one to right of glove box), and none have anything written that would tell me which fuse is for trailer running lights.
Anybody know:
1. Where the fuse is located
2. What type of fuse it is
Greatly appreciate your help!
4mula1fan, Thanks for pointing me in the right direction. You were in the right church, but wrong pew. For the 2016 it's located one fuse over (pointing to it with red probe):
I went ahead and added the photo to the link you sent me as well.
There's more than one fuse. Test light check every fuse under the hood, including fusible links, and every fuse inside the cab.
Dan09, if you have zero power to any of the 7 pins, I'd start right there at the receptacle and work back toward the fuse box. I wouldn't be surprised to find a rodent has disconnected your wiring under the truck with its teeth or something.
1 - 10 of 10 Posts
