A little history, and looking for a second opinion. I was pulling my 07 Titan out of the driveway and it stalled out. But would not restart at all, still cranks over fine. I did the obvious and swapped ipdm relays. Still no start, then swapped out the fuel pump and completely switched ipdms with another truck and still no start.
At a lost cause now other then getting it towed into the stealership.
Any help would be great, thanks.
ECU? I don't know what they cost around you, but here the one for my truck is $75 used (yes I checked and made sure that it was the right one). Barring that I'd say perhaps a fuse going to something to do with ignition or fuel. Does it smell like fuel after kicking it over a couple times?
I have no fuel smell I can hear the fuel pump priming I've pulled all fuse and visually check. The condenser fan is running as well and anti theft is on solid now. I can get it so somewhat start by spraying starter fluid in the throttle body.
Then it sounds like you definitely have a fuel problem. I don't know what it takes, but you should check the fuel pressure at the rail. IIRC, its supposed to be 51 PSI at the rail.
Yeah the only problem is that the condenser fan is on and the anti theft is solid which makes me think electrical, like ecu is fried.
