1 - 2 of 2 Posts
Hey all,
I have been searching and searching and still cannot get an answer. My truck, 2009 King Cab 4x4 with a 1.5" spacers on front, has developed a random clunk from the rear of the truck. Only seems to happen when i hit a small crack/dip or when i make a turn. Usually seems more pronounced when its a bit warmer out side. Its like something just has enough play in it to shift over. Shocks and struts seem to check out OK. All shackles look good. Exhaust is down and tight to where it is not touching anything. Tailgate seems to hold tight as well.
Any suggestions on what to check and or tighten to remedy this? Truck only has 64k miles on it. Bad bushing somewhere? Bed Bushings?
All help appreciated.
does your tailgate shock dampen all the way up and down? could be the bushing is
mangled and the p-side socket on the tailgate has a little play
1 - 2 of 2 Posts
