Hi all,
I replaced my lower control arms with some Detroit axle ones (I know, i know) Its making a noise from the passenger side suspension when i go over larger bumps with any speed.Sounds like of metal on metal. Everything is tight, i double and triple checked tonight. I thought it was the swaybar endlinks i installed being too small but nope. I fully removed the swaybar to rull that out. The noise sounds almost like a scraping sound.
I have three thoughts, and id like input before i go buying an OEM control arm from nissan.
1. I completley forgot to transfer the bump stop. the new control arms do not have one. Could this be causing the issue?
2. I used these to replace the factory bolts i had to cut: https://www.amazon.com/dp/B000V55IK6?psc=1&ref=ppx_yo2ov_dt_b_product_details perhaps they arent allowing the bushings to move (I think this is the least likely as they were able to align the truck)
3. The ears for the struts were bent, i mostly fixed them, but I am not positive there is enough room for the strut to move without rubbing. WIth that said, it makes no noise when moving slowly.
I am currently thinking it is the bumpstop.
A few notes
1. Leaving the garage which has about a 4 inch drop going 5 mph is enough to trigger the noise.
2. Compressing the suspension with the jack then letting it drop very quickly does NOT trigger the noise.
3. The swaybar was contacting the driver side LCA, but its been removed with no change to the noise.
4. The driver side was replaced as well and is not making noise as far as i can tell.
5. The balljoint on the driverside fought me like crazy to seat all the way.
A few notes
